Shonuff
#1 Posted : Friday, June 13, 2014 10:09:04 AM(UTC)
Shonuff
Fridge is about 11 years old. Last couple weeks freezer and food side temps were both high. Called local tech board had burnt mark on back. Wanted $300 to replace. Replaced myself. While replacing noticed buildup of frost on back freezer wall. Removed all ice, let fridge sit for bought an hour. Food side temp is 37 freezer is 24, after 24 hours.
#2 Posted : Saturday, June 14, 2014 8:02:32 AM(UTC)
What is the frost pattern on the evaporator coils.
Shonuff
#3 Posted : Saturday, June 14, 2014 2:32:40 PM(UTC)
Shonuff
Full of ice looks like Michigan in winter.
#4 Posted : Sunday, June 15, 2014 12:56:38 AM(UTC)
Defrost the coils and measure the stabilized temperatures.
#5 Posted : Sunday, June 15, 2014 12:56:50 AM(UTC)
Shonuff
#6 Posted : Sunday, June 15, 2014 3:16:01 PM(UTC)
Shonuff
Defrosted coils after 24 hrs. Freezer holding at 0° fridge holding at 29. Fridge does not want to reset to 37°.
#7 Posted : Monday, June 16, 2014 1:12:53 AM(UTC)
Most probably your defrost thermostat/limiter is bad, just replace
