confusedincc
#1 Posted : Wednesday, June 11, 2014 5:01:19 PM(UTC)
confusedincc
Novice here! Forgive the non-tech rambling!
I have an old top freezer maytag ptb1753drw. The Relay Overload start device fried.
I bought a replacement called a Kenmore Maytag Refrigerator Relay Overload Start Device, with 3 wire connections on one side and 3 receptacle holes that attach to the compressor. 2 holes are round and connect to the white and orange wires and there's a hole looks is like a mini jack-o-lantern smile with a round hole just below it which connects to the blue wire. The orange and white wire holes and jack-o-lantern hole were completely scorched. The blue wire did not fry so the round hole below the jack-o-lantern hole didn't fry so badly.
I replaced the burnt flag connections and am ready to plug the relay onto the Embraco EGU 70HLC compressor. However, I am not sure what the prongs on the compressor should look like.
2 are plain round prongs and one has a weird rectangle piece of metal on the end. I don't know if it's supposed to be there or if it's from the guts of the fried overload relay. It looks rather melted.
I found the 2009 thread: "Compressor Connections (Relay/Overload Protector)" thread and richappy's answer that "The start device may be arc welded to the compressor pins. Bust off what you can and use a dremel with grindstone to dress up the compressor pins."
Is this what I'm seeing? Do I need remove it? Do I really need a dremel?
Does anyone have a pic of the Embraco EGU 70HLC compressor prongs? Should they just be 3 plain round prongs?
Thanks to any info and your patience for reading this through!
confusedincc attached the following image(s):
confusedincc
#2 Posted : Wednesday, June 11, 2014 5:38:53 PM(UTC)
confusedincc
Hey!!! Good news! I answered my own question!
Someone had a pic on ******** so I saw the prongs and see that metal blob thing is not supposed to be there!
I'm going to operate!!
I hope the patient survives!
#3 Posted : Thursday, June 12, 2014 1:17:17 AM(UTC)
Very good. Be careful with the damaged pin, the metal might be brittle from the heat, bust it off and the compressor is toast.
confusedincc
#4 Posted : Thursday, June 12, 2014 1:58:02 AM(UTC)
confusedincc
Thanks for the fast reply...
So you can see the little cap on the prong in the pic?
Would it help to try applying a bit more heat directly on that fused cap (like a hobby electric soldering iron) to get it off?
Or will that make it more brittle?
I don't have a dremel but maybe I have a grindy drill bit.
It's still in fridge and sideways...hard to reach. Do I dare undo 3 of the foot pins to swing it to me or am I begging for problems?
I am not a repair person, just too poor to buy a new fridge right now and somewhat handy. I'm also an old, arthritic dame so I need technique over brute strength.
Any tips besides dremel??
#5 Posted : Thursday, June 12, 2014 2:06:42 AM(UTC)
Yes, remove the compressor retaining clips and swing the compressor out so you can grind the bad pin.
confusedincc
#6 Posted : Sunday, June 15, 2014 3:45:27 PM(UTC)
confusedincc
Thanks for all the advice.
I couldn't pivot the compressor with the copper piping in place but managed to get the metal blob off, plugged on the new relay thing and have a 38º fridge and about 4º freezer.
It has cycled on and off a few times so I hope it's good to go.
