close up view d-man-d attached the following image(s):
Touch it up with a bit of solder. You will need a fairly high wattage iron for this. Probably 40 or more watts. Put it back in and works perfectly! Thanks! d-man-d attached the following image(s):
For anyone looking to replace the relay itself. Here's the part information:
Mfg: Song Chuan Mfg Part #: 832A-1C-S-12VDC
Update. I did this fix over 3 years ago. Still working, no problems.
