I have a GE Profile PSS26NSTC SS Side by Side. The problem I am having is that the freezer will thaw out too long, then it will freeze again. The ice melts and the ice cubes all freeze together. Of course the other items in the freezer thaws out too long also. Any ideas what could be causing this? Thanks KJD
Check for a bad solder joint behind the motherboard in the back
