todddavid
#1 Posted : Friday, June 6, 2014 2:16:32 PM(UTC)
todddavid
In moving the washer to the basement I broke off timer knob. Where can I get information to replace the knob or will I have to replace more than just the knob? and where to find a replacement. The washer works but seems to stop in different parts of the progression of washer cycles. Thanks so much!
sidfink43
#2 Posted : Saturday, June 7, 2014 4:50:08 PM(UTC)
sidfink43
Here is the exploded parts diagram for your model.
03-Control Panel parts for Frigidaire FTF530FS1 - AppliancePartsPros.com
If the shaft on the timer is ok then you can just replace the knob, otherwise if you broke the shaft you will have to replace the timer.
