tomlizc
#1 Posted : Friday, May 8, 2009 5:57:03 PM(UTC)
tomlizc
:confused: Need help, my dryer has stopped heating. At the same time the heat went completely out my timer went from max of 60 min to over 2 hours without going off.
What parts will I need to fix this problem.
Thanks!
#2 Posted : Saturday, May 9, 2009 3:01:27 AM(UTC)
Replacement parts for WHIRLPOOL TEDS740PQ1 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208576793.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure the voltage at the plug.
L1 to L2 = 240 volts
L1 to Neutral and L2 to Neutral = 120 volts
Try the unit in timed dry.
Now does the timer advance?
If yes then odds are high that your heating element has burned out.
In Timed Dry this unit's timer motor gets it's power basically directly from the power in.
In Auto cycles it gets power through the heating element when the thermostat shuts the element off so if the heater goes, no power to the timer motor and no heat is the result.
Best to check it with a meter for resistance with the unit unplugged.
But usually you can see the broken filament.
Remember to unplug the machine when working on it.
240 VOLTS IS LETHAL
tomlizc
#3 Posted : Saturday, May 9, 2009 1:26:22 PM(UTC)
tomlizc
Thank you for your reply!
I usually use the 60 minute timed cycle. It moved very slowly to the off position but took over two hours.
Just to clarify what parts I should order: heating element definitely
Should I order any of the following: thermal fuse, dryer cycling thermostat, thermal cut off for dyer heating element for 309 degress, thermaostat fixed
Thanks again for your help
#4 Posted : Sunday, May 10, 2009 2:59:54 AM(UTC)
I am assuming that the unit did shut itself off after the 2 hours and that the 240 volts is OK.
If this is correct then the most likely culprit is the timer.
Only if it is blown. Confirm this either visually or with a meter.
Note: it will have no effect on your timer problem as you are getting long run times in Timed Dry and it is not in circuit in Timed Dry mode
I would not unless you can confirm they are shot with a meter.
Guest (4)
