silk8635
#1 Posted : Sunday, June 1, 2014 9:17:23 AM(UTC)
silk8635
My dryer will not dry anything , you can turn it on and timer counts down and everything ,but the drum does'nt turn and there is no heat. The last time that it did work it was very overheated. What should I do? Please help me. Thanks in advance.....
#2 Posted : Monday, June 2, 2014 2:13:38 AM(UTC)
Parts for Whirlpool WED6200SW1 Dryer - AppliancePartsPros.com
Could be that the thermal fuse on the blower assembly blew.
Could be that the thermal fuse on the blower wheel (Item 7 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
File Attachment(s):
WED6200.pdf (417kb) downloaded 6 time(s).
whirlpool dryer not drying (Dryer Repair)
by slushdog69 6/10/2009 8:16:14 AM(UTC)
by loq24 12/2/2008 9:14:55 AM(UTC)
Whirlpool Dryer not drying good (Dryer Repair)
by hmfary1 2/12/2008 7:16:03 AM(UTC)
