We were getting multiple F1 codes and I have since replaced both oven sensors and just replaced the control board and ran a test.
Ran range to max out both ovens at 475 at the same time and got the F1-1 code again.
Thoughts?
Following is a link to a manual. You will have to join the site and be logged in to be able to download the manual. http://appliancejunk.com...wnloads;sa=view;down=390Have you calibrated the oven temperatures. The procedure is in the manual Page 5-2. Does the unit run OK if you do not run both at the same time at this high heat settings? It may be normal as you are running both units very hot. Did this unit ever run without an error when you did this test? Has anything changed with the way the unit is mounted? I am thinking there may be an air flow problem. F1-1 is an upper oven error and you are generating a lot of heat in both compartments so the error will show up on the uprre unit first re: heat rises. |
THIS FORUM IS DEAD!!!!!!! |
