Issue Just Started, Running a normal load under "Normal Setting" unit goes through the wash cycle and shuts down. It does not dispense the fabric Softener, it does drain the water from the tub, (Clothes are dripping but no water lying in drum), there are no error code that shows. Resetting /restarting produces same results.
