Good to find this forum with all the helpful people.My washer started to have a problem about a week ago,it works just fine till you get to the spin cycle and then it loses it.It rinses and then when its time to spin, it just spins weakly and has a clicking noise to it.It will start to go full speed and then the clicks start and it stops spinning.I replaced the clip on the bottom that holds the clutch on a few weeks ago,it was broke on one side thinking that was the problem but now it has started again with the clicking.Sounds like it just does not want to hook up and spin.Any suggestions are appreciated at this time with this problem.
