Yuan
#1 Posted : Tuesday, May 20, 2014 4:27:30 PM(UTC)
Yuan
My oven's broiler works – high and low settings, and the top burners work.
However, the bake temperature is low. It starts to heat up – the oven starts at 100 degrees, it gets to 153 degrees and stops. It never heats up over that.
There is no malfunction code.
What's wrong? Sensor? Igniter?
Thanks,
yuan
Yuan
#2 Posted : Friday, May 23, 2014 4:22:11 PM(UTC)
Yuan
I hired a service man. He replaced the igniter and the problem is fixed.
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Upper oven temperature lower than displayed by 75degrees (Oven Repair (including Ranges and Cooktops))
by BillIan 10/22/2014 12:41:56 PM(UTC)
by schredder 9/30/2008 7:35:08 AM(UTC)
