Hello all, and thanks in advance for any help you may be able to give me. Today I was using my ice dispenser, I switched it to crushed ice and depressed the lever. As soon as I pressed the lever I heard a faint sound, which to me sounded like a fuse popping, coming from below. Immediately after the sound it stopped dispensing ice. I opened the freezer door to have a look to see if anything was jammed up and I smelled a faint smell of something that resembled burnt rubber which lasted for about 10 seconds. The auger does not spin and no noise is made when I depress the lever. The water dispenser and all other features seem to work normally. The model # is GD5RVAXVY05 Thank you for taking the time to read about my issue. Brian
I am not sure how much this helps, but here is a pic. lbsrdi attached the following image(s):
Does anyone know how to gain access to the motherboard on this model? Thanks in advance.
