- Dryer ran for about 5 minutes, turned and heated up normally, then quit completely. No heat, no tumbling. Door switch is functioning normally. Breaker is fine. You can feel a slight, inaudible, vibration when you press the "Start" switch.
thermal fuse, perhaps?
-KEYE660WWH1
Yes, it could be the thermal fuse. If the unit will not start again. Unplug the unit and check the fuse with a meter. If it is blown be sure to check/clean your vent system as that is the most common cause of the fuse popplng.
If it restarts after a couple minutes then it is probably related to the motor. |
THIS FORUM IS DEAD!!!!!!! |
That was it, thermal fuse. Thanks.
