daughdrill1
#1 Posted : Sunday, May 11, 2014 6:50:39 PM(UTC)
daughdrill1
Dryer will tumble and igniter will glow, solenoid will click but no flame. I have verified that gas is flowing with no leaks or blockages and have replaced the thermal fuse and the 2 solenoids. I have also removed and checked the continuity on the igniter, flame sensor and cycling thermostats. Everything checked out okay. I let it run for about 30 mins and the igniter would glow the solenoid would click and nothing. It would cycle through this sequence intermittently. What am I missing?
daughdrill1
#2 Posted : Thursday, May 15, 2014 5:56:47 PM(UTC)
daughdrill1
I put the lower panel back on and reattached the vent hose. After running for about 5 minutes the flame finally ignited.
Guest (4)
Gas Dryer will not ignite (Dryer Repair)
by bnhandyman19 11/23/2013 2:35:57 PM(UTC)
Gas dryer will not ignite (Dryer Repair)
by shannonsjackson 11/26/2012 3:18:47 PM(UTC)
by JoshK 10/22/2012 7:51:48 AM(UTC)
