Comingchaos
#1 Posted : Wednesday, April 9, 2014 10:54:50 PM(UTC)
Comingchaos
Hi guys, I have an old GE stove. I have no idea how old it it so I'll add a picture of it and of the model and serial numbers. My question is which bake element would I need for it? I noticed it had a hot spot and then today it fried and I thought it was going to start a fire in the oven. Anyway, the element is toast. I just need to know which element to get. Thanks!!! :)
WED5100.pdf (128kb) downloaded 6 time(s).
Comingchaos attached the following image(s):
#2 Posted : Thursday, April 10, 2014 12:50:14 AM(UTC)
I think the foll0owing is the correct element.
Part number: AP2031097
I think this is the element you need but am not 100% sure as the parts breakdown for this unit does not come up.
You can check the dimensions using the one inch squares.
Be sure to check how far the element extends into the back of the unit. If this is too long then the element will short out against the rear cover.
Also it is bets to talk to the parts representatives, they have more info than I have.
Comingchaos
#3 Posted : Thursday, April 10, 2014 7:15:24 PM(UTC)
Comingchaos
Thank you! I'll check out the old element and compare the two
Comingchaos
#4 Posted : Saturday, May 10, 2014 4:23:58 AM(UTC)
Comingchaos
So I got the bake element for my oven and it fit right, the size was right and all that. Put it in and turned it on to check it out and it only got up to about 200 degrees, and that took over an hour. I had it set on 350. Any ideas why this would be? I changed the setting on the back of the temperature knob and nothing changed. Is there a reset button or relay somewhere maybe? I took the back off and looked at all the wires and they all look good, but I didn't test any yet. Are there different size elements as far as volts or anything? I figured they would all be the same as long as it's electric and it runs on 220. Any ideas? Thanks
#5 Posted : Sunday, May 11, 2014 6:03:52 PM(UTC)
No all elements are not the same wattage but they are usually close.
Did the element stay on all the time when i preheat?
Most ovens switch back and forth between the bake and broil elements but I cannot find any info on this unit so cannot say that this unit does this.
Could be that when the element blew it damaged the thermostat.
I am on the road till the end of the month so my online time is iffy
PS doing this on tablet is not a lot of fun!!!!
