tmjpman
#1 Posted : Friday, May 2, 2014 3:16:12 PM(UTC)
tmjpman
Hello, I have a Kenmore Elite Dishwasher 630.13959010. Everything mechanically is fine but the problem is that several of the led “lines” on the control panel are not lighting up. I want to replace the control panel so I took the front cover off but I cannot figure out how to remove the control panel from the metal housing. Any help would be greatly appreciated.
bbgun
#2 Posted : Monday, May 5, 2014 2:57:15 PM(UTC)
bbgun
Have you removed the two scews on either side of the door latch yet? Not sure how far along in the removal process you are.
