RBD245.pdf (420kb) downloaded 8 time(s). Is the suction line suppose to be crimped on this or did the previous owner have this messed up? He had a serviceman come in to fix compressor and then could never get it to run right. It has been sitting for 2 months and he gave it to me. They have since moved. Am I correct in my thinking to that being the reason it won't get cold Mandirigma attached the following image(s):
THIS FORUM IS DEAD!!!!!!! |
But correct me if I'm wrong please. Shouldn't the process line be crimped and suction line be hooked to system for circulation of refrigerant?
I may be wrong but I think on this compressor that is the process line. |
There is an arrow pointing at it saying suction. On a video I saw it says the embraco compressor has the processing line on the right side looking at compressor. So am I wrong in saying the service person hooked up the wrong line to system?
From what you say it does sound like it is hooked up incorrectly.
I just cannot see how a tech would do this but I guess stranger things have happened. |
