jyoung
#1 Posted : Thursday, May 7, 2009 9:39:38 AM(UTC)
jyoung
The water dispenser on the front of the sis-by-side refrigerator appears to be leaking. How do I remove the cover on the ice/water dispenser for troubleshooting?
Thanks- John
woodchuckie
#2 Posted : Thursday, May 7, 2009 2:34:06 PM(UTC)
woodchuckie
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Although the leak may be because the water inlet valve on the back where the water supply comes in is leaking. You can disconnect the line (usually left) and see if it's dripping.
Need to patch or replace water dispenser line (Refrigerator & Freezer Repair)
by kmerenda 6/9/2012 4:21:04 AM(UTC)
Replace water dispenser lever (Refrigerator & Freezer Repair)
by mopsmom 5/17/2009 6:36:02 PM(UTC)
Replace Water Dispenser Reservoir (Refrigerator & Freezer Repair)
by babylonboots 11/8/2008 9:30:14 AM(UTC)
