jack finnell
#1 Posted : Tuesday, April 29, 2014 7:44:52 AM(UTC)
jack finnell
This is a LG Freezer/Refrigerator. Water is pooling on the bottom of the freezer and then freezing. I have turned off the water to the ice-maker but water still forms. Looks like water just might be coming from what looks like a vent in the back of the freezer.
roger100
#2 Posted : Wednesday, April 30, 2014 7:19:33 AM(UTC)
roger100
Your problem sounds very familiar. I would guess that the defrost water drain line is plugged or frozen, so that the drain water has no place to go except to the bottom of your freezer. In time the drain water would leak out on to the floor. There are several threads on this forum concerning the same problem & fixes. My KitchenAid requires a replacement part in the drain line, which KitchenAid has offered to replace at no cost to me. Good customer service !
Roger
Leaking water in freezer compartment (Refrigerator & Freezer Repair)
by stressman4 1/23/2009 8:25:25 PM(UTC)
