SML2008
#1 Posted : Wednesday, April 23, 2014 7:55:54 PM(UTC)
SML2008
Frigidaire Affinity dryer stopped working. We've replaced a thermostat, checked everything else we're supposed to, checked incoming electric, and still wont run. Before new motor heating element worked. Now we have to manually engage the centrifugal switch to get it to come on and dryer motor still wont run, hum, whine, nothing. Please help, we are at a loss.
#2 Posted : Thursday, April 24, 2014 4:56:40 AM(UTC)
Parts for Frigidaire AEQ6000ES1 Dryer - AppliancePartsPros.com
Below is a manual. You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...&id=259;t=1398342688
Looks like the wiring diagram on page 48 is the same as your unit.
[COLOR="Blue"]We've replaced a thermostat, checked everything else we're supposed to, checked incoming electric, and still wont run. [/COLOR]
Which thermostat?
I only see the high limit thermostat and that should not effect the motor starting.
Was it checked with a meter and found to be open?
[COLOR="Blue"]
Before new motor heating element worked.[/COLOR]
This points to a problem because there should not be any heat with the motor off re: the centrifugal switch for the heater should be open.
[COLOR="Blue"]Now we have to manually engage the centrifugal switch to get it to come on[/COLOR]
This is how it should work.
Be careful as having heat with no air flow can cause overheating and blow the thermal limiter and perhaps the hi-limit.
I am assuming that if the unit has a drum light that it works.
To check a few things.
Unplug the unit.
Measure from Neutral (probably best to use the prong on the line cord) to J4-1 on the control board. Should be an an ohm or two (motor windings).
If OK
Measure from L1 to J4-2 on the control board , should be 0 ohms with the door switch closed.
Use the most sensitive resistance scale on the meter. It is also a good idea to short the meter leads together before starting so you can see if there is a zero offset in the meter.
If both the above checks are OK and since you have replaced the motor I would say that the control board is toast re: the motor relay contacts are not closing.
SML2008
#3 Posted : Friday, April 25, 2014 4:56:34 AM(UTC)
SML2008
Can I get that manual in another file type? I have tried everything I know and can not open it. By the way, the thermostat we changed was the one on the blower housing unit. Still trying to get everything else double checked. Put new motor in and got error code E5b. We had changed the thermal dryer fuse on back cabinet wall and the high limit thermostat tested good. Will double check heating coil.
#4 Posted : Friday, April 25, 2014 11:29:38 AM(UTC)
The manual is only available as a .pdf.
Download and install the latest version of Adobe Reader and it should open the file.
I am not sure if you have Adobe as the default program to open .pdf files.
If not I would do that.
SML2008
#5 Posted : Sunday, April 27, 2014 11:42:43 AM(UTC)
SML2008
Hello, we checked your suggestions and both were ok. Running another error code test we now get e9e. Is this still the electronic contol panel?
#6 Posted : Monday, April 28, 2014 2:11:26 AM(UTC)
I double checked my link to the manual and it did not work so I am try the following if you still do not have it.
http://appliancejunk.com...wnloads;sa=view;down=259
e9e is a line voltage problem.
Check the voltage.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
SML2008
#7 Posted : Monday, April 28, 2014 6:26:34 PM(UTC)
SML2008
While checking the electric we discovered the outlet dryer plugs into is high at 280 volts. Each leg reads 140v. Could the excess current have fried the control board? Or is something else the culprit?
#8 Posted : Tuesday, April 29, 2014 2:55:50 AM(UTC)
That is way too high.
I would call your electrical supplier.
Yes it could have caused problems.
