Mike4069
#1 Posted : Wednesday, April 23, 2014 10:29:20 AM(UTC)
Mike4069
We have an intermittent cooling problem with our Maytag MSD2732GRS
refrigerator. It cools fine when it runs, but sometimes shuts down and
doesn't restart.
I diagnosed this as a defrost timer problem by manually advancing the
Invensys S-68233-2 8 hour timer with a screwdriver, although I had to tap
on it after I heard the "snap" before the refrigerator would start.
The problem persisted after I replaced the timer. Also, the old one seems
to work fine in a bench test. The gears spin, and the state does change
from run to defrost and back. I advanced it manually to a few minutes
before the run-to-defrost transition, then let it make both transitions on
its own. I stopped the test after that one iteration.
With the new timer installed, the refrigerator makes the transition from
run to defrost, but more often than not hangs up just a couple of clicks
short of the transition back to run. If I advance the timer manually,
sometimes the refrigerator comes back on, and sometimes it does not.
In the latter case, I can get it to run by tapping next to the timer.
A few times, I have heard the fans falter and surge repeatedly after I
restart the refrigerator by tapping near the timer. With a few more taps,
it will run smoothly, so far.
This sounds like a loose connection, but I would appreciate any hints on
where to look or how to diagnose. The schematic folded up inside the
control section is for a model with adaptive defrost, so it is not that
useful for troubleshooting.
#2 Posted : Wednesday, April 23, 2014 11:25:44 AM(UTC)
Parts for Maytag MSD2732GRS Refrigerator - AppliancePartsPros.com
Below is a link that comes up for this series of units even if yours is not listed on the first page.
You will have to join the4 site and be logged in to be able to download the manual.
http://appliancejunk.com...e&id=40;t=1398280554
Instead of tapping try moving the temperature control up/down a little to see if that fires the unit up.
It may be that the thermostat is sticking open.
Finding a bad connection can be a royal pain.
I would check the crimps on the wires at the timer.
Check for any deformation in the wires themselves.
It will just take time and a lot of patience unless you are having a very lucky day.
