mwmcdona
#1 Posted : Wednesday, April 23, 2014 7:11:11 AM(UTC)
mwmcdona
When cycle completes, there is an inch of water in bottom and dishes are not clean with soap spotting. Only way to evacuate water is to run CANCEL/DRAIN function prior to new load. Have checked drain line for restriction-none.
I gravitate towards rebuilding pump if all controller sequencing is time based then it stands to reason if pump efficiency is off it will empty slower.
Could it be a controller issue?
How can I troubleshoot?
Mike
#2 Posted : Saturday, April 26, 2014 2:38:59 AM(UTC)
Your model number is incomplete.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
Frigidaire won't drain fully! (Dishwasher Repair)
by drainwoes 4/11/2012 3:43:26 PM(UTC)
