After a recent power outage I had to replace the main & tactile board. Now the clean light flashes continuously. Not 7 times. The dishwasher will not start. I checked the door latch and it's okay.
No I didn't. I have the original board but cant locate the part/plug you are referring to.
I located it. I'll transfer it tomorrow. Do you think I damaged the new board by not transferring the plug? Thanks for your help.
I transferred the resistor. The dishwasher is fixed. Thanks.
You are welcome. I'm glad you were able to fix it.
I also replaced the board but discarded the old one. How can I obtain that plug?
Originally Posted by: Gene You are welcome. I'm glad you were able to fix it.
Gene. Gene, like a dummy, I discarded my old control board before receiving a new one for my GE gld5850l15cs dishwasher. I have installed the new control board and also have the continuous blinking clean light. I know it is because the model select resistor is missing. Where can I look up the correct value resistor for my gld5850l15cs GE dishwasher? Thanks in advance!
