dap4cep
#1 Posted : Wednesday, April 16, 2014 4:15:29 AM(UTC)
dap4cep
I have a GE wall oven that shows F8 on the screen. I looked at general codes and it shows meat probe. This unit doesn't have that. I'm not sure if it could be the ERC. Does anyone have any info on this model?
#2 Posted : Friday, April 18, 2014 3:46:00 AM(UTC)
I do not have access to GE tech data by model so can only give general info.
When I look up GE fault codes the one that comes up most often for F8 is a failed ERC.
Have you tried removing power fro the unit for a couple minutes to see if it will reset?
dap4cep
#3 Posted : Sunday, April 20, 2014 7:41:00 AM(UTC)
dap4cep
I did try disconnecting the power. It didn't clear the code.
#4 Posted : Sunday, April 20, 2014 4:20:53 PM(UTC)
Then looking at the usual codes the control board is toast
Whirlpool gas oven fault code (Oven Repair (including Ranges and Cooktops))
by Repairit2 2/12/2013 5:11:04 AM(UTC)
GE Oven Fault Code: F2, F3, F5 - only after oven is on > 45 min. (Oven Repair (including Ranges and Cooktops))
by mrmsu 1/30/2012 7:44:28 AM(UTC)
Amana Gas oven Fault Code F3 (Oven Repair (including Ranges and Cooktops))
by Edul 11/17/2010 10:42:56 AM(UTC)
Oven Fault Code F3 - Need some part numbers (Oven Repair (including Ranges and Cooktops))
by orionlbb 2/21/2010 11:39:56 AM(UTC)
Whirlpool Built in Oven Fault Code - E2 F3 (Oven Repair (including Ranges and Cooktops))
by RockChalk 1/1/2010 5:42:07 PM(UTC)
whirlpool electric oven fault code e3 f2 (Oven Repair (including Ranges and Cooktops))
by heidi 2/3/2009 10:26:18 AM(UTC)
Whirlpool double Oven Fault Code E6 (Oven Repair (including Ranges and Cooktops))
by sjarrad 11/18/2007 6:42:01 AM(UTC)
