gutliaed
#1 Posted : 11 years ago
gutliaed
My refrigerator compressor started short cycling in the last week or so. Basically it runs for 30-60 seconds, briefly clicks off, then restarts right away. It is cooling but not completely (frig temp was 51 and freezer was 29).
First, I cleaned all the coils and checked the fan and it didn't help.
I had a refrigerator repair guy out, who told me it was the invertor box and wanted to charge me $400 to replace. This guy didn't test anything with meters or anything, even when I asked him to. He stated he knew this was the problem.
When I was opening up the back of the frig myself to see if I could replace the inveror box myself, I unplugged it for about 20 minutes and had jiggled some of the connections to the box while inspecting it. When I plugged the frig back in, it seemed to run well. in fact it ran straight for several hours, which I figured was it's effort to cool to the proper temps. It did get to normal temps then. It ran normally for about 24 hours, then began short-cycling again.
I ended up finding the invertor box myself for $155.51 and replaced it. Again, it ran normally for awhile, but only 3 hours or so, when it began the same short-cycling.
Please help with any ideas of what this may be and how to test for it! Thanks!
#2 Posted : 11 years ago
Turn the cold control to the coldest setting. If it still short cycles, you have a bad compressor.
