2 Pages<12
fairbank56
#11 Posted : Tuesday, April 15, 2014 12:49:13 PM(UTC)
fairbank56
Groups: Expert
The 6 flash error means locked rotor, which simply means the motor did not run when it was supposed to, not necessarily that the motor is faulty. You would get a 7 flash code for a lid switch that failed to open. To really determine what the problem is, you would need to monitor voltages at the inverter connectors when the problem occurs. I would say it's likely the motor as they are a high failure item in these washers but it could be a faulty control board at control panel or a bad connection.
Eric
Gebabe
#12 Posted : Tuesday, April 15, 2014 4:03:39 PM(UTC)
Gebabe
Hi Eric, All is well now. I bought a new washer this afternoon. I really appreciate your efforts to help me with this, and your great explanations. Your input helped me make this decision. You are an asset to this forum.
2 Pages<12
