bkid49
#1 Posted : 16 years ago
bkid49
my ice and water maker will make ice and it comes out door, but i have replaced both values on water line on back of ref. and put in new filter and and the plastic container behind food drawers is not frozen but i cant get any water out of the door to drink. there is ice cubes that will come out but no water . what do i check now?:confused:
AIMANNY
#2 Posted : 16 years ago
AIMANNY
Ok On The Botten Of Your Refg Under The Kick Cover. The Water Line Runs Up Your Freezer Door. Undo The Conneter. Now Close The Freezer Door Have A Cup Raedy. Push The Water Dispenser. Does The Water Come Though The Open Line Uner The Door.
bkid49
#3 Posted : 16 years ago
bkid49
i took the kick plate off and pulled the hose out of the elbow and pushed the water button and no water came out of hose. now what . and thank you for the help.
bkid49
#4 Posted : 16 years ago
bkid49
bkid49
#5 Posted : 16 years ago
bkid49
i have not herd any more no water now what.
woodchuckie
#6 Posted : 16 years ago
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. If the water goes to the ice maker you'll know your actuator switch is working and the problem could be a frozen line at the water reservoir behind the crisper in the fridge.
If the water doesn't go to the ice maker I would suspect the water actuator switch. Part 7 on diagram 6. Replacement parts for FRIGIDAIRE FRS22ZRGW2 | AppliancePartsPros.com
bkid49
#7 Posted : 16 years ago
bkid49
i will try that thur. morn. and see i know the reservoir be hind crisper is not frozen have allready done that and check the elbow on freezer door not water there. i am a women so thank you for the help. will let you know thur. if that is it thanks
bkid49
#8 Posted : 16 years ago
bkid49
not sure how this site work either , but will try that , thank i am a women and trying to do so will get back to you thur. on swithing wire. i know the thing behind draw is not frozen done looked at that . but there in no water at elbow on freeze bottom near kick plate.
