rpearce
#1 Posted : Thursday, December 13, 2007 4:19:51 PM(UTC)
rpearce
:cool:
WASHER WILL RUN THROUGH WASHING CYCLE. WHEN IT GOES TO DRAIN
CYCLE IT CUTS OFF. THE MOTOR IS NOT RUNNING & I HAVE CHECKED THE PUMP & DRAIN LINES. I DIDN'T FIND ANYTHING WRONG . COULD IT BE THE TIMER OR CONTROL BOARD:confused:
abbie
#2 Posted : Thursday, December 13, 2007 5:25:38 PM(UTC)
abbie
First thing I would check is the lid switch or the strike on the lid that fits in the hole in the cabinet THE SWITCH SHOULD MAKE A CLICKING NOISE WHEN YOU TEST IT.
rpearce
#3 Posted : Friday, December 14, 2007 2:37:06 PM(UTC)
rpearce
I checked it everything is o.k. with the lid switch? Do you have any other suggestions .
Guest (4)
