While using the convection oven everything when out. No panel control or any light at all. Checked power supply to oven and found 240 volts. The oven had been cooking for apx 15 min when this happened. No noise or odor. I found 2 internal fuses and checked them--they tested fine but only one has power. What could have happened?
Check TCOs. That is what went in mine.
