saintsokwitit
#1 Posted : Thursday, April 23, 2009 4:42:30 AM(UTC)
saintsokwitit
Just about everything in the fridge compartment of my side by side freezes up or ices up no matter what setting the thermostat is set at unless at zero. Any setting above zero and things just freeze up till I eventually set thermostat to zero. It just started doing this a couple of months ago.
woodchuckie
#2 Posted : Thursday, April 23, 2009 5:28:38 AM(UTC)
woodchuckie
Cold air enters the fridge through a damper or vent between the freezer and fridge. The evaporator fan in or behind the freezer blows the air through. There is an adjustment to open and close this vent to allow more or less cold air in. The fridge temp control may not be closing it.
saintsokwitit
#3 Posted : Thursday, April 23, 2009 6:11:12 AM(UTC)
saintsokwitit
I've had the fridge for 9 years and it just started doing this.
saintsokwitit
#4 Posted : Wednesday, May 6, 2009 4:48:40 PM(UTC)
saintsokwitit
ok, now the freezer has pretty much stopped working. It will get cold enough to freeze things but just hours later I go back and everything is starting to thaw.
woodchuckie
#5 Posted : Wednesday, May 6, 2009 5:25:41 PM(UTC)
woodchuckie
Take the cover off the back inside of the freezer and see if the evaporator coil is ice up blocking the flow of air.
saintsokwitit
#6 Posted : Wednesday, May 6, 2009 8:05:21 PM(UTC)
saintsokwitit
what do I do if the evaporator coil is icing up? what is next step?
woodchuckie
#7 Posted : Thursday, May 7, 2009 4:12:25 AM(UTC)
woodchuckie
Check defrost heater
Defrost thermostat and
Defrost timer part 6 on diagram 3.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
