HELP! I have an LG Refrigerator, Model# LFX25971ST. The LED lights in the top of the refrigerator have burned out (I was told LED lights lasted for ever?). I have located the correct replacement LED Light Board on the AppliancePartsPros.com web site (EAV43060808), but before ordering it I want to verify the dimensions of the LED Light Board inside my refrigerator. I tried to remove the plastic cover by removing the two screws I thought were holding it up, but the cover is still in place. I do not want to force it and possibly break the plastic, so my question is; what is the "trick" to removing this plastic cover". Thanks in advance for your help. Nort
Originally Posted by: Nort  HELP! I have an LG Refrigerator, Model# LFX25971ST. The LED lights in the top of the refrigerator have burned out (I was told LED lights lasted for ever?). I have located the correct replacement LED Light Board on the AppliancePartsPros.com web site (EAV43060808), but before ordering it I want to verify the dimensions of the LED Light Board inside my refrigerator. I tried to remove the plastic cover by removing the two screws I thought were holding it up, but the cover is still in place. I do not want to force it and possibly break the plastic, so my question is; what is the "trick" to removing this plastic cover". Thanks in advance for your help. Nort Hey Nort!! I found a link to the appliance repair manual, for your For your LG LFX25971 refrigerator But I can not post it here, so please just go to Google, and search for this exact term, "LG LFX25971 repair manual" I hope that helps you my friend!
