When I just use the time option and turn the dryer in it will run for about 10 minutes and then stops with all the lights blinking.
When I use the normal setting on the dial it automatically turns on the 50 minutes and it will run for about 10 minutes and then I will get the AD error code. I did read up a little and did clean the sensors with rubbing alcohol but that has not done the trick.
Since it only runs for a short while I am not completely sure it it does not produce any heat but I think it doesn't.
Hi this is the problem my dryer AFFINITY model FAQE7073KA0 stop in a few minute and 3 blinking lights cycle status
THANKS FOR ANY HELP
VLADO
