brian44
#1 Posted : Thursday, December 13, 2007 1:23:42 PM(UTC)
brian44
My dishwasher is stuck in drain cycle. We had a water leak around the door seal. Crud builds up along the seal then it leaks. We clean it off and it stops leaking. This time apparently moisture got to a sensor? Where is it?
leggman
#2 Posted : Thursday, December 13, 2007 3:59:36 PM(UTC)
leggman
take the kick panel off and sopp up the water in the base assytheres a float just left of ctr. that runs drain pump and goes into lockout.
