I'm replacing the thermostat and the wiring isn't matching. The existing thermostat has one orange and one yellow wire while the replacement unit I'm trying to install has one red and one white wire.
Can someone advise of the proper connections?
Thanks!
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
I am not sure which thermostat you are replacing but if it is a two wire device, it should not make any difference as basically you are just adding a temp controlled switch at the end of the wires.
I would go Red to Orange and White to Yellow. |
THIS FORUM IS DEAD!!!!!!! |
Denman is correct, It makes NO DIFFERENCE!!!!!!!!:)
