Leroy1945
#1 Posted : Friday, March 28, 2014 12:38:43 PM(UTC)
Leroy1945
Dryer will not shut off. It heats and does everything it is supposed to do, but will not shut off.
#2 Posted : Sunday, March 30, 2014 4:12:18 AM(UTC)
Parts for Whirlpool GEX9868JT0 Dryer - AppliancePartsPros.com
Does it do this in both timed dry and auto cycles.
if it shuts off OK in timed dry then it could be just dirt etc. between the sensor strips of the moisture sensor.
File Attachment(s):
GEX9868.pdf (618kb) downloaded 0 time(s).
Whirlpool Gold Senseon Ultimate Care II Dryer shutting off!! (Dryer Repair)
by thkirkland 11/11/2009 6:33:10 AM(UTC)
