2 Pages<12
strogdon
#11 Posted : Thursday, March 27, 2014 6:53:10 PM(UTC)
strogdon
I am experiencing the same thing with my Whirlpool. I've had no problems with it's functioning, but when I unplugged it and cleaned it out, I noticed the back was bulging. I pushed on it and heard water sloshing. I have never repaired a refrigerator, but couldn't imagine that much water could be trapped back there! Please let me know if your solution works! Thanks!
Chicagojoe
#12 Posted : Friday, March 28, 2014 6:04:48 AM(UTC)
Chicagojoe
Ultimately the problem was with the timer. Once I replaced the timer, I could remove the wire and everything works as originally designed. The water behind the wall was due to ice build up in the freezer. The ice separated the panels and allowed water to run down the back of refrigerator. I made a small slice and siphoned the water out using 1/4" plastic tubing as you can see in the photo. Everything runs well now.
strogdon
#13 Posted : Friday, March 28, 2014 4:26:12 PM(UTC)
strogdon
Thank you so much! I'll give it a shot myself. Sorry you had that problem, but glad I found you!
Fuz
#14 Posted : Sunday, December 17, 2017 7:25:35 AM(UTC)
Fuz
Have you had any insight into this problem? we are having the same issue with Kenmore Coldspot
2 Pages<12
