derektuan
#1 Posted: : Tuesday, March 25, 2014 5:59:38 PM(UTC)
derektuan
My original thermistor did not have continuity I replaced two new thermistor part # 35001191 from AppliancePartsPros but they ran for 1 minute and I heard a popped and a burned smell from the thermistor plastic outer case. Does anyone know which other part that I need to order to avoid another blow thermistor?
Any help is greatly appreciated.
Thank you!
Derek:confused:
#2 Posted : Wednesday, March 26, 2014 3:17:34 AM(UTC)
Parts for Maytag MDE9700AYW Dryer - AppliancePartsPros.com
[COLOR="Blue"]I replaced two new thermistor[/COLOR]
I am not sure what the above means.
Did you replace the thermistor twice with the same result?
Sounds like it is a control board problem. The thermistor is getting too much voltage and therefore blowing.
I do not know what the voltage should be as they do not publish board schematics.
I would check the wiring to the thermistor to be sure that it has not grounded out to the frame.
If OK then perhaps check the voltage across the thermistor (pins 2 to 6, they do not give a plug number).
I would think it would be between 5 and 20 volts DC.
Check it for both DC and AC volts.
File Attachment(s):
MDE9700.pdf (120kb) downloaded 9 time(s).
derektuan
#3 Posted : Wednesday, March 26, 2014 7:09:07 AM(UTC)
derektuan
Thanks Denman!
Yes, replaced two new thermistor.
I will check the reading on the control board. Do you think the thermostat need to be replaced along with the thermistor to make this work?
Thanks,
Derek
#4 Posted : Wednesday, March 26, 2014 10:48:08 AM(UTC)
[COLOR="Blue"]Do you think the thermostat need to be replaced along with the thermistor to make this work?[/COLOR]
No.
The thermostats are just safety devices and should not cause the thermistor to blow.
derektuan
#5 Posted : Monday, March 31, 2014 11:18:30 AM(UTC)
derektuan
denman - Thanks again for your help. My dryer is now fixed.
