GregChar
#1 Posted : Sunday, March 23, 2014 11:46:39 AM(UTC)
GregChar
Dryer won't start.
Tested Thermal Fuse with ohm meter and is the problem.
When changing the Thermal fuse, should I also change the High limit thermostat?? Or something else?
- The vent was completely clear so that was not the cause.
Thank you
fairbank56
#2 Posted : Sunday, March 23, 2014 1:27:36 PM(UTC)
fairbank56
Groups: Expert
No, hi limit should not need replacing however the operating thermostat may need replacing. Did you check the dryer internal venting? Inside the blower housing, heater box, exhaust vent, heat intake duct? Check blower seal and drum seals?
Eric
GregChar
#3 Posted : Sunday, March 23, 2014 1:47:40 PM(UTC)
GregChar
I did check and found no other obstructions. Looked fine otherwise.
I will replace thermostat. Anything else as long as I am replacing these 2 parts?
Thank you
GregChar
#4 Posted : Sunday, March 23, 2014 1:50:32 PM(UTC)
GregChar
Dryer thermistor ??
fairbank56
#5 Posted : Sunday, March 23, 2014 2:22:31 PM(UTC)
fairbank56
Groups: Expert
Yes, sorry, I didn't check the tech sheet. This dryer uses a thermistor.
Whirlpool 8577274 Dryer Thermister - AppliancePartsPros.com
Eric
GregChar
#6 Posted : Sunday, March 23, 2014 3:19:04 PM(UTC)
GregChar
I have ordered the parts and am glad for your help !
