lester smith
#1 Posted : Friday, March 21, 2014 11:52:48 AM(UTC)
lester smith
original overload/start relay has 4 wire hookup replacement p/n w10189190 only has 2 wire hookup. part came with no instructions................how is it hooked up?
#2 Posted : Friday, March 21, 2014 1:00:31 PM(UTC)
The original parts where a klaxon overload and a black ptc starter.
Remove these items and install the new device.
you have no run capacitor, so the extra wires go to the condensing fan motor.
The two power wires from the fridg go to the new start device, the other two probably go to the condensing fan motor.
You will probably have to splice these to the two fridg power wires to get the fan motor running.
lester smith
#3 Posted : Friday, March 28, 2014 5:21:45 AM(UTC)
lester smith
Thanks for the help.........BUT.......I'm looking for a concrete (100%) correct answer to my wiring question.....NOT a these wires PROBABLY go to ..... I want to know exactly were they go................ Thanks
#4 Posted : Saturday, March 29, 2014 9:58:52 AM(UTC)
If you have a boxed device with overload and klaxon, it's impossible to blow out your compressor.
Specific wiring info I can't give without seeing your fridg.
Guest (4)
