David A Long
#1 Posted : Sunday, March 16, 2014 10:05:19 AM(UTC)
David A Long
I replaced the inlet valve and the washer now fills. However, it isn't doing anything during the wash cycle. It does seem to drain. What's next?
Thanks,
David L.
mr_mjsjr
#2 Posted : Sunday, March 16, 2014 1:51:55 PM(UTC)
mr_mjsjr
what was the original problem? a bosh has a pan that holds water when there is a leak. water in the pan pushes up a float that cuts power to the wash motor. if you spilled water during your repair or there was some sort of leak originally, that may be the issue
David A Long
#3 Posted : Sunday, March 16, 2014 2:23:17 PM(UTC)
David A Long
The original problem was, water wasn't getting into the machine. I don't see any pan under the machine anywhere. Just the sump.
mr_mjsjr
#4 Posted : Sunday, March 16, 2014 2:54:08 PM(UTC)
mr_mjsjr
sorry, this appears similar to ge. there is generally a float switch that may be stuck up. the unit thinks it is to full and will not progress.
David A Long
#5 Posted : Sunday, March 16, 2014 3:03:13 PM(UTC)
David A Long
Makes sense. Sounds like I need to locate the float if it has one. Thanks.
