I have a ge range and I think there is supposed to be a wiring diagram and code sheet somewhere on the range, behind a panel perhaps? I was hopeful you could point me in the right direction before I take all of the sheet metal off of the unit. The code isn't a common one that shows up in your forums. the code flashed FA 30. I have had the back off already and it isn't there.
