My Samsung Washing machine wont spin correctly. It turns but when it tries to go to a high speed spin I get an 3E error message. According to the Technical Information manual this means "Over-current is detected. Motor won't turn. (IPM detects over-current)" Corrective action is "Evaluate wire harness for loose or unhooked connections. Go to "Quick Test Mode" to test Motor." I went to "Quick Test Mode" and the motor turns. I can't find any loose or unhooked connections.
Anyone know what the issue is?
