my washer will start spinning but once water fills to a certain point it stops spinning, the door stays locked, water doesn't drain and I get an error code...
Originally Posted by: kbaney1987 my washer will start spinning but once water fills to a certain point it stops spinning, the door stays locked, water doesn't drain and I get an error code... its a LG Direct Drive model WM2016CW
