markj1
#1 Posted : Monday, March 10, 2014 4:35:43 PM(UTC)
markj1
Hi, need to replace the original motor pulley with a bigger 27 mm pulley per Samsung bulletin to fix the problem of belt being prone to slide. I have no idea how to get the pulley off the motor, I don't see any screw or bolt holding them together. The motor is still attached to the blower. Any help is appreciated.
