lobo7448
#1 Posted : Monday, March 10, 2014 10:44:55 AM(UTC)
lobo7448
Replaced heating element and thermostat, but dryer is still not heating.:eek:
#2 Posted : Tuesday, March 11, 2014 2:10:47 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Jenn-Air JDE2000W Dryer - AppliancePartsPros.com
The first thing to do is check the power. The heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
