tan in back of frigidaire cooktop stove shows #316424187 as a model number. Gas range. Door shuts all the way except what normally pulls it in the final 3/4 inch or so. I have read posts on this problem. Is there a way to tell if the receiver is the problem or the hinge?
The given model number comes up as a part not a model number. Please check it.
Remove the door and re-install it. the operators manual should tell you how to do this. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The given model number comes up as a part not a model number. Please check it.
Remove the door and re-install it. the operators manual should tell you how to do this. The number showing on the back is the only one I can find. Any suggestions on where to look elsewhere? The paperwork is still in a bag on the back of the stove, but no numbers at all listed on the 2 page manual or wiring schematic. The range in in a bad place to remove the door right now, I will try to do it a little later today. Thank you for the response. Gary
How about this one.
Frigidaire FGF366DSA.
I took the door off, reinstalled and it still will not close the last 1/2 inch.
thanks.. gary
