Arneld
#1 Posted : Monday, March 3, 2014 4:58:48 PM(UTC)
Arneld
When you turn the machine on it makes a humming noise but the drum does not turn. I took the lid off and started turning the drum by hand and it continued on it's own. But when I truned it off and on again it still did not start on it's own.
fairbank56
#2 Posted : Monday, March 3, 2014 6:58:30 PM(UTC)
fairbank56
Groups: Expert
If it's not difficult to rotate drum by hand, then it sounds like a faulty motor switch. You would have to replace the motor as switch alone is not serviceable. See if it will start/run with belt removed. You will have to hold start switch since belt switch is open with belt removed.
GE WE17X10010 Dryer Motor Kit - AppliancePartsPros.com
Eric
Arneld
#3 Posted : Tuesday, March 4, 2014 10:48:07 AM(UTC)
Arneld
Since the drum rotates on the front panel can I remove the back panel to remove the belt? Does the back panel support the back of the drum or is it independent of the back panel?
fairbank56
#4 Posted : Tuesday, March 4, 2014 11:28:36 AM(UTC)
fairbank56
Groups: Expert
No, you will have to remove front panel unless there is an access panel on rear (some GE's have them).
Eric
