Hi, I purchased a Adaptive Defrost Control #61005988R from you. When I went to hook it up, it appears the previous owner replaced the control with another brand (part #03AU06A-1). In doing so, he cut off the molex plug and now I have no idea which wire goes to which pin. By any chance is there a picture of the control with the molex plug attached so I can install the part? Thanks...Jim jiminoregon attached the following image(s):
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I think that will work. It shows which color wire goes to each leg. I'll give it a try. Thank you, very much. Jim
