First water was leaking and we thought it was the tub seal. Replaced the tub seal. Water still leaked, and it was for sure coming from the drain pump. Replaced the drain pump. Now no water is leaking, however, it squeals/whines while it agitates. Anyone have any thoughts why???:confused:
Groups: Expert
Run it with pump pulled away from motor to see if noise is coming from new pump.
Eric
I just ran it without the pump attached to the motor, the squealing stopped. Does that mean the new pump is bad? Or can I do something to the new pump to fit it?
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Run it with pump pulled away from motor to see if noise is coming from new pump. Eric Please help, do I need to buy another pump?:confused: :confused: :confused:
Groups: Expert
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I bought my new pump, part number 3363394 by whirlpool, from amazon. I don't understand what the difference is? Other then the price.
