cassiessary
#1 Posted : Wednesday, February 26, 2014 12:36:56 PM(UTC)
cassiessary
A few days ago, my dryer wouldn't turn on. The light doesn't come on and nothing happens when I push the start button. I took it apart and checked the door switch, start switch and thermal fuses. All are good to go. Here's what I know is wrong: there is no continuity between L1 and N at the terminal block. There is also no continuity between L1 and the start switch, but there is continuity between L1 and the timer. All the connections look good, I don't see any frayed wires or anything. Help!
fairbank56
#2 Posted : Wednesday, February 26, 2014 2:51:51 PM(UTC)
fairbank56
Groups: Expert
Need the correct model number, the one you gave is not it. Reset the breaker in your breaker panel for dryer.
Eric
